Question on a new clutch for a warrior
Old Apr 3, 2005 | 11:28 PM
GOHARD's Avatar
Default Question on a new clutch for a warrior
The old warrior is gonna need a new clutch,its a 94 model.What would you suggest getting and what kind of task is it putting a new one in?
Thanks
Old Apr 4, 2005 | 01:18 AM
AZDUNERAT's Avatar
I used a barnette, feels just like stock on the pull but hooks up better on the launch. 105 bucks at my local shop. Take off the side case unscrew about five nuts then use an impact hammer to remove the boss housing. Slide out old fibers, and count in new fibers, make sure the small one is the first on there. Replace the boss nut and lock washer, install combination of three new springs and two old(or vise versa depending on how hard you want the pull). Make sure you have a screw driver pressed behind the housing to keep it tight, you should not be able to move the fibers with your finger when back together. Put side case back on, however make sure you have aligned the push rod even with the case housing. Put on oil and ride
This was my experiance
Aaron
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
manuelrivera
Aug 8, 2015 04:34 PM
Lpshann
Sport Quads
Jul 29, 2015 08:11 AM
200es
Jul 10, 2015 09:09 AM
