How hard would it be to put a larger motor in a quad?
Old Apr 4, 2005 | 01:03 AM
jason399's Avatar
Default How hard would it be to put a larger motor in a quad?
Hey guys I was just lookin on ebay and I see 350 warrior motor and I was wondering how much fabrication would it take to bolt that up to my beartracker which is a 250 motor?.. I think there would be plenty of room but the main thing is the driveline, how hard would it be to put all that together, its shaft drive.. or would it be easier to just bore out the 250 as much as possible to squeeze more power out of it? anyone ever do anything like this I know Ive heard of people putting crotch rocket motors in quads... well if anyone has any imput let me know.. thanks guys
Old Apr 4, 2005 | 01:30 AM
Alky's Avatar
man you would be better off just buying a warrior w/ all the work you would have to do ...imo
Old Apr 4, 2005 | 01:54 AM
jason399's Avatar
I dont want another quad I have no room for another one.. I just want to beef it up so it has some more power.
Old Apr 4, 2005 | 05:52 PM
MSGT's Avatar
Explore the route of getting an overbore kit with a cam and pipe first. Unless you have all the die grinders and welders, that is a huge undertaking. To pay a machinest is just not cost-effective.
I have a project blaster chassis that I'm stuffing a Yamaha XS400 twin into, but the chassis cost me nothing, and it was in sad shape anyway. I had the engine sitting around in my garage for years. I have nothing to loose but my time. I have all the requisite tools needed to undertake such a project.
Old Apr 5, 2005 | 11:36 PM
yamahalltheway's Avatar
Hey let me know if you can get that engine in there or how big you can bore out b/c i got a 02 beartracker and have 25 inch itp 589 in readr and need alil more hp like 300 or 350 so let me know if you can fit engine or how large you can bore it to Thanks
Old Apr 6, 2005 | 01:51 AM
JakalWarrior's Avatar
Heres what all has to happen. Sprocket has to lign up horizontally AND vertically otherwise the chain will drag on things or be crooked and mess stuff up (Assuming both bikes are chain drive, dunno wth you do if they arent). The shifter has to be in a decent place. You have to pray the stock exhaust has moderately usable routing or youll be buying custom fab work. Of course you have to fab up some motor mounts and transfer all the electronics making the appropriate brackets to hold them. Then the small stuff like throttle set up, cltuch set up, it goes on and on and on. And thats just the expected stuff, there are other things that just crop up. I wouldnt do it unless your making a really cool hotrod or something. Not worth it to make a slow bike a bit less slow.
Old Apr 6, 2005 | 11:29 AM
MSGT's Avatar
The old 400 twin I have (like the chassis) is a Yamaha, is rather compact, electric / kick start, and runs on points ignition. Just to do this, the chassis needs to be lengthened by four inches, the diagonal bracing through the middle has to be moved, new mounts must be fabricated and welded in, and the gas tank will have to be changed to something different. The exhaust will be a "Y" to a single exit, and the airbox in the rear fender can be resused with minor modifications. The brakes and suspension do not change, but I may lengthen the rear swing arm just a bit to balance out the chassis change. The rest of the controls and electrical are a minor undertaking.
I would not do this to a machine that was new or in decent shape. This was a junkyard dog that I got for free.
Old Apr 6, 2005 | 11:53 AM
well the reason i want to know if it will work is becase all i do is mud mud mud and i have 25 in ch tires and notice a powerloss so i want more cc like 300 or 350 but this thing is pretty ragged out and way so it is not that big of a deal and the engine on it now needs to be rebuilt it has a leaking head gasket burns some oil not allot and runs alil funny at times so i do need to overhaule or repalce[img]i/expressions/face-icon-small-smile.gif[/img] ok well let me know how many cc u get from most you cant boor or if u can get engine in
Old Apr 6, 2005 | 04:23 PM
wildcatkit52's Avatar
On the Blaster you will have a serious issue with the stock brakes. I am in the middle of changing my Blaster brakes over to Banshee brakes. I am also lengthening and widening the stance. I ordered A arms for it and am going to run an extended swingarm with Banshee axle or Warrior axle.(if I find that they are the same length as the Banshee) This Blaster is for my GF to ride. It has been worked over a bit so that it runs about like a stock 250R. The stock brakes are NOWHERE NEAR being good enough to stop properly.
DTroyer01
Jul 3, 2015 07:34 AM
VRRRRT
Jun 27, 2015 09:38 AM
Dabears1983
Jun 23, 2015 04:59 AM
Stillonit
Jun 18, 2015 11:23 AM
NONEtooSMART
Jun 17, 2015 08:48 AM
