Dissapointed raptor owner
Old Apr 11, 2005 | 07:22 PM
  #21
raptorRACER16's Avatar
Default Dissapointed raptor owner
ya maybe ill mess around with my carbs and see what happens
Old Apr 12, 2005 | 02:37 AM
  #22
huskerjim's Avatar
Guys this thing only has 15 hours on it I hope the valves don't need adjusted as well I just purchased a complete exhaust kit header and piupe for the raptor from WB I already have a KN on it will do the carb adjustments as well will let you know the results at a later time ride on guys....
Old Apr 13, 2005 | 02:09 AM
  #23
Jibrille's Avatar
You need a kick in the pants for being easily beat by a Turd, and if you race the same pred and lose again with the mods you're getting, I'll have to come down and kick you in the pants.
Old Apr 13, 2005 | 11:14 AM
  #24
huskerjim's Avatar
plz do....[img]i/expressions/face-icon-small-smile.gif[/img][img]i/expressions/face-icon-small-blush.gif[/img]
Old Apr 13, 2005 | 08:38 PM
  #25
hillbilly660's Avatar
should i adjust the floats to factory specs?
Old Apr 13, 2005 | 08:41 PM
  #26
ZoomZoom14's Avatar
i dunt kno much about raptors...but im glad to see another Huskers fan!!!!!![img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 13, 2005 | 09:53 PM
  #27
bassetboy55's Avatar
with those mods and the right jetting you shouldnt lose to preddys. also gearing shouldnt be a problem.
Old Apr 13, 2005 | 11:42 PM
  #28
huskerjim's Avatar
COME OCTOBER, THIS HUSKER WILL BE IN BIG RED COUNTRY TRYING TO ROOT THE HUSKERS A VICTORY OVER THE SOONER LOSERS....
Old Apr 14, 2005 | 03:20 AM
  #29
Freez's Avatar
The way the factory sets them is way too high and causes poor fuel atomization. You need to drop the level by about 2 to 3 mm.
If you know how to check the float level with a clear tube, attached to the drain plug on the float bowl, then set it to 3mm above the split.
You will be amazed how much extra power you get from that. That will give you almost the same power gain as adding a pipe.
Old Apr 14, 2005 | 02:21 PM
  #30
huskerjim's Avatar
Guys I hate to tell you this, your all BS'n yourselves. The float level will only effect the ride with flooding it or starving the bike for fuel, adjusting it for more HP it's not going to happen sorry. But if you want to keep telling yourselves that to make you feel better so be it. [img]i/expressions/face-icon-small-wink.gif[/img]
