banshee vs YFZ450
Old Apr 10, 2005 | 05:17 PM
raptor6's Avatar
Default banshee vs YFZ450
I have a raptor that will be for trails!!!! I want a drag qaud so thats why i want the 450 motor. what should the hp be?
Old Apr 10, 2005 | 05:21 PM
redneckcav24's Avatar
Then why did you ask which will handle trails better in your post. You never mentioned anything about a drag. I say go with the YFZ either way.
Old Apr 10, 2005 | 05:32 PM
2fun's Avatar
I have a 2003 raptor right now but I will be buying a used banshee or a used YFZ450. Whats faster with pipes filter and jets? what will handle the trails better? and what will handle better?
This was your first post......
"What will handle the trails better"?
"What will handle better"?
Now you say this........
"I have a raptor that will be for trails!!!! I want a drag qaud so thats why i want the 450 motor. what should the hp be?"
If you are only using the next quad to be a "drag qaud" then who cares about trails and handling?
Just dump a bunch of money into the Banshee, and have a fast drag quad that is only used for drags.
You might want to specify these things in your first post next time.
Old Apr 10, 2005 | 05:35 PM
raptor6's Avatar
Because at 1st I was going to ride it in the trails but I can just ride the raptor in the trails. What would the 450 motor be pushing.
Old Apr 10, 2005 | 05:41 PM
  #15
2fun's Avatar
A piped YFZ with an aftermarket air filter, properly jetted will net you about 46-48 RWHP
Doing the "free" cam mod will net you another 1-3 HP at different RPM ranges (mostly on top end).
Don't let the numbers fool you. The YFZs put out a TON of torque when properly jetted and piped. Torque is what helps to accelerate you. A bike with a lot of torqe and a flatter power curve will be quicker than a bike with a higher but more "peaky" power curve.
Old Apr 10, 2005 | 05:57 PM
  #16
raptor6's Avatar
thanks,know what will the banshee 450 motor mod be pushing?
Old Apr 10, 2005 | 06:03 PM
  #17
enFORCER's Avatar
Hard to say... How big is the crank????? What kinda port work was done???? On gas I would guess 60hp to 70hp....
Old Apr 10, 2005 | 06:05 PM
  #18
vinny3299's Avatar
yeah i agre with that... but remember the banshees are two stroke, haveta do that oil and gas mix Crap i perfer not but the yfz450 rocks and i wouldnt trade it for anything out there..
Old Apr 10, 2005 | 08:39 PM
  #19
raptor6's Avatar
What would the top speed be on the banshee?
Old Apr 10, 2005 | 08:46 PM
  #20
enFORCER's Avatar
Depends on gearing.... (16-40 90mph+) (12-44 60mph) something like that....
