Why are the 2-strokes (Blaster and Banshee) bad for trails? Why aren low rpms bad for 2-strokes (Blaster and Banshee)?
Originally posted by: GOHARD
I have a ? Its not good to hold 2 strokes wide open for very long right?
Plese correct me if im wrong.
What are the things u can do and shouldnt do to a 2 stroke and a 4 stroke?
Thanks
Thanks
Originally posted by: Scooter86
Two strokes that are set up for a big hit in the powerband tend to tire the rider faster. There are motors out there set up for a smoother power delivery that are great on the trails. One example is the 85/6 LT250R. They have decent power across the RPM range right from the factory(i.e., no big hit anywhere) You can set up a Banshee for more low end also, but it takes money to smooth out that hit some. If your engine is jetted correctly, then lower RPM shouldn't be a big problem for a two stroke. Of course, you will still foul plugs quicker than a four stroke, but I wouldn't say low rpms are 'bad' for the engine.
Originally posted by: ZimRaptor
thats the reason i dont like 2 strokes...the power band is in the top end, and u cant be holding the throttle there for very long, thats why 2 stroke owners (No offense!) have to do top end rebuilts quite a bit, 4 strokes on the other hand u can rev the living snot out of and nothing bad will happen...btw i dont recommend WOT on any engine for more than 5-10 seconds
Thanks
Thanks
"btw i dont recommend WOT on any engine for more than 5-10 seconds"
Could someone please explain the above statment , what he means exactly.
#15
#16
...and also low RPMs for 2-strokes can also result in plug fouling.
#17
#18
#19
#20
