HMF question
Old Apr 21, 2005 | 07:44 PM
Warrior02man's Avatar
Default HMF question
just put my slip-on on and started it up. its rly load, but thats not my question. My question is that it idles very high, and i rode it. WHne i came back, i noticed the connector piece from the slip on to the head pipe was slightly brown. Why? Am i seposed to do soemthing after putting it on? am i ruinning lean or rich.. i did adjust the air/fuel screw and that is when it idled very high.. thx!
Old Apr 21, 2005 | 08:06 PM
IATVHSSracer's Avatar
When i put mine on it was a little high and i messed with the idler and it was fine it runs like a champ
Old Apr 21, 2005 | 09:11 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
the pipe browns.. it's just browning from the heat, and the material it's made of. Also if YOU don't rejet.. you're gonna run lean..
Old Apr 21, 2005 | 09:27 PM
bberck's Avatar
What speedy said
Old Apr 21, 2005 | 10:31 PM
think i can run it for a couple weeeks like this? 2-3 weeks untill i getting it jetted..
Old Apr 21, 2005 | 10:33 PM
86LT250RFatty's Avatar
on a warrior, yes, HMF"s jetting specs just say to adjust the airscreew, why dont you move the needle clip up one posistion (richer) that will give you more power..
holeshotz8436's Avatar
its gonna take 2-3 weeks for the jet kit to get there?
Old Apr 22, 2005 | 09:10 AM
no/... when i get it installed
Old Apr 22, 2005 | 09:11 AM
where is that? is that the screw that is facing the clutch side on the carb? it has a lil springy thing in the middle of it.. is that what ur talking about? its gold..
Old Apr 22, 2005 | 09:15 AM
Speedy2222's Avatar
No that's the idle screw... the fuel/air screw is on the bottom side of the carb.. toward the back.
