Flipping warrior rims?
Old Apr 23, 2005 | 11:06 PM
YBlasterboy's Avatar
Default Flipping warrior rims?
I want to flip the front rims, but the valve stem hits the brake.Is there anything i can do to it without buying spacers.Any help is appreciated.Also, if i flip the back rims, will it be wider?
Old Apr 23, 2005 | 11:08 PM
bberck's Avatar
For the front you have to move the valve stems or could try shorter ones not sure how much they hit. I have my back wheels flipped and makes it about 2 in wider.
Old Apr 23, 2005 | 11:14 PM
Rider1169's Avatar
On the front rims, i flipped my raptor fronts and the valvestem hit, i just put a few washers inbetween the rim and the hub. It spaced it out just enough to clear the stem from the caliper setup. If this doesnt work, you can get flush valvestems or take off the tires, flip that valvestem inside out, drilla hole in the opposite side of the rim, and install a new valvestem----Good luck---Rider1169
Old Apr 24, 2005 | 01:04 AM
ok, thanx paul, i didnt think about putting washers there.
Barnsnelbon
Sep 27, 2015 03:07 AM
PinkFloydEffect
Sep 25, 2015 06:31 PM
Bernhard
Sep 25, 2015 12:45 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
black_thunder
Sep 20, 2015 10:21 PM
