Drain gas from Grizzly
Old Apr 26, 2005 | 05:40 PM
hondabuster's Avatar
Default Drain gas from Grizzly
I just use the float bowl drain, then you dont have to siphon. Put the drain tube in a gas can, open the screw, and have the fuel petcock to pri, or res, and let gravity do the work.
Man...i was thinking times are tough, but you got me beat.
Old Apr 27, 2005 | 03:22 AM
WyoBullRydr's Avatar
Well, it wouldn't be so bad, but I used about forty bucks of my monthly gas budget to buy the cv boot kit for the grizz. You know, priorities. I got enough out with the turkey baster and siphoning to get me back a forth to work, so it all worked out. And I get paid onct a month, so budgeting is important, or so the wife tells me. Glad you like the avatar Starky, It does look pretty cool. [img]i/expressions/face-icon-small-smile.gif[/img]
Old Apr 27, 2005 | 01:59 PM
CobraR6's Avatar
When we drained the tank on my Bruin we disconnected the line.
Old Apr 29, 2005 | 10:35 PM
katman's Avatar
starky you took the words right out my mouth.[img]i/expressions/face-icon-small-happy.gif[/img]
Old May 3, 2005 | 02:50 PM
  #15
Well, got enough out through Starky's avice and siphoning. I think I got chemical burns on my lips. I don't think gas is ever going to go down. It sucks. I was using the baster and it fell apart. Then the bulb would not stay on, then I went to siphoning. Shouldn't need to do that for a while now. Thanks again.
Old May 3, 2005 | 03:30 PM
  #16
Next time use the drain on the bottom of the carb, just slip the hose into a 5 gallon can, turn the screw, go have a cup of coffee, and its done...with no gas on the lips.
ReconBayou
Oct 31, 2022 05:37 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
cboler9
Sep 24, 2015 08:35 PM
wrencher82
Sep 24, 2015 03:39 PM
