how do you get the steering stem bearing out on a 2003 banshee?
Old Apr 27, 2005 | 02:10 PM
NastyNate03's Avatar
Default how do you get the steering stem bearing out on a 2003 banshee?
hey i have a 2003 banshee im tearing apart to powdercoat the frame how do you remove the steering stem bearing i used a rubber mallet but it didnt budge what else can i do or is there any special tricks on getting it out let me know thanks
Old Apr 27, 2005 | 02:48 PM
AlkyBurninX's Avatar
Have you removed the nut? The one with hex on the inside and threads on the outside that is on top of the bearing. If so, the bearing usually falls out.
Old Apr 27, 2005 | 03:06 PM
alright i just went out and looked at it i took off the black rubber pieces on the outside so then i saw the hex nut alright i got this far how do i go about getting that hex nut off do i need a big allen wrench if so what size and can i find it at any tool store
Old Apr 27, 2005 | 03:22 PM
Well, you have couple options.
1) Go to the Yamaha dealer and let them charge you out the *** to pull it.
2) Take a chisel and hammer and tap it around to loosen it. Usually they aren't too tight and your '03 shouldn't be rusted.
3) The best and easiest way is to run down to the hardware store and find a bolt that has a head that fits close to the size of the hex inside the nut. Buy it and two nuts for it. Jamb the nuts together on the end of the bolt (if you don't know what I mean take two wrenches and tighten the nuts to each other). The put the head of the bolt in the bearing nut and loosen it by turning the bolt nut on the bottom. This is what I have built and I have took probably 12-15 bearings out with it. I had one bearing nut that was extremely tight and I ended up tack welding the bolt nut to the bolt to remove it because I couldn't jamb the nuts together tight enough. I can try to get you a pic of the tool I made, but I don't know when I can get it to you.
Old Apr 27, 2005 | 03:28 PM
think i know what your talking about the tool if you can a pic would be nice but i think i understood you right if you can can you get the size of the top you used to put in the hex bolt it would make it easier for me to find at the store instead of making 2 trips to get the right size
Old Apr 27, 2005 | 03:36 PM
Head of the bolt I use is 1 1/8". It is not a tight fit but it works. I think 1 1/4" is too large. I am not positive but I am pretty sure its a 3/4" bolt.
Old Apr 27, 2005 | 03:40 PM
alright so a 1 1/8 socket will fit on the head and the thread body is 3/4 thick
Old Apr 27, 2005 | 03:45 PM
[img]i/expressions/face-icon-small-wink.gif[/img]You got it!
Old Apr 29, 2005 | 09:54 PM
alright today i went to the hardware store and bought the nuts n bolt i went home and did what you said it works that was a great idea AlkyBurninX so then i went to East Coast Atv after that and droped off my frame to get powder coated candy red ill get pics of it when i get it back
Old Apr 30, 2005 | 10:01 AM
Glad it worked for you. Poor boys have poor ways[img]i/expressions/face-icon-small-smile.gif[/img].
Are you going to have silver vein as a basecoat? I saw one frame that was red candy translucent over silver vein base and it looked awesome.
