blaster wont run! need help bad!
Old May 2, 2005 | 11:16 PM
badscrambler400's Avatar
Default blaster wont run! need help bad!
alright. i been at this thing for probably six months now. i bought a 91 blaster that was non runnin for 500 bucks. the guy got into some trouble and was goin to jail. he told me it ran when he put it up 4 years ago. well come to find out the crank was shot and so was the top end. i replaced the crank, bearings, seals, top end, ignition coil, oil block off kit. well i mixed it with 87 octane gas and i mixed it 30:1, new plug and wouldnt even sputter. then i pulled it around and after a long long time and in about third gear half throttle it just popped really loud and roared to life. then in about 2 seconds died. this happend a few times until i fould a plug. found out i was running way too rich on the idle circuit so i fixed that and put the jetting back to stock and i did it again. this time it sheered a cheap flywheel key. so i did it once again and popped really loud took off then died, did that a few times and then just nothing. also one time this happend and it popped really loud, started then died and there was dark dark black oil EVERYWHERE. well i had to tear down the bottum end and use yamahagasket on the cases because it was pulling trans fluid into the cylinder so i fixed that problem. well i ordered good flywheel keys from yamaha and havent had that problem since but it still wont run. i cleaned the stator and flywheel very good and adjusted it a little because i thought that might contribute to the flywheel key. well im getting spark, getting fuel, and i have about 150 lbs of compression. i also replaced the ignition switch thinking that was the problem but i have no clue. does anyone have any ideas? thanks soo much!
Old Jul 2, 2005 | 11:01 PM
Storj's Avatar
check out your carb its probaly all gummed up from sitting so long
Old Jul 3, 2005 | 12:21 AM
UltimateAussie's Avatar
yeah if you havent cleaned your carb thers your problem right there. the reason it eventually starts is becuase after a while the enngione sucks enough gas throught the jet to make it start but not enought to make it run. definatly cheack out your carb
Old Jul 3, 2005 | 06:06 PM
chazekxt's Avatar
or it could be the tors unit on top of the carb it will fire for a few secs then die. thats what mine did . unplug the tors and she fired right up. it might be that..too
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
