aftermarket speedometer
Old May 7, 2005 | 09:06 AM
rcnitro's Avatar
Default aftermarket speedometer
is there such a thing for 2000kodiak 400 mine only has indicator lights for what gear you are in. would like to know how manyhrs i put on now i use gps but would rather have somthin on the bike thanks in advance..
Old May 7, 2005 | 11:39 AM
rc3's Avatar
rc3
trailtech makes this sort of thing, you can go to there site and check it out Trail Tech
Old May 8, 2005 | 08:59 AM
rcnitro's Avatar
thanks but i dont see any for kodiak though. lol oh well gues ill just use gps. thanks again though
Old May 8, 2005 | 03:46 PM
NLWarrior01's Avatar
Does your kodi have front disc brakes? if so you should be able to use the same kit as for the Warrior/Raptor/Banshee. Just involves replacing one of your rotor bolts with a a magnetic one, and mounting the sensor in the rotor guard. Then you just program the unit with your front tire circumference, and you're off to the races.
Old May 8, 2005 | 05:03 PM
rcnitro's Avatar
yes it does . where would i look at getting this kit at?
Old May 8, 2005 | 08:41 PM
rc3's Avatar
rc3
trailtech, just get the speedometer kit for a raptor or warrior, and then buy a universal handle bar mount, that would be the best, it has instruction on how to program it.
Old May 9, 2005 | 06:55 AM
Actually, the kit comes with everything you need to install it, including the handlebar mount. You can get them from just about any ATV store for under $80.
Keep in mind though that your GPS will be more accurate for speed. But the trailtech does accumulate hours as well and I believe you mentioned that.
Old May 9, 2005 | 08:13 AM
rcnitro's Avatar
OK i will check out local dealer pretty reasonable he is. thanks again for all the help.
fd24
Jan 16, 2019 08:59 AM
EIF
Apr 20, 2017 07:15 PM
cboler9
Sep 24, 2015 08:35 PM
rawbdiggity
Sep 7, 2015 12:05 PM
byronman
Sep 6, 2015 06:34 PM
