FCR Carb
Old May 10, 2005 | 01:55 AM
maddog56's Avatar
Default FCR Carb
I purchased the MSR fuel adjustment screw with the big numbered head. The problem is that I cant get my stock fuel screw out. I unscrew it all of the way but it wont drop out. I tried a magnet but I think its brass or something similar and its not magnetic. Is there a trick I'm missing? There was nothing in the instructions besides a direction to unscrew the stocker.
I spent almost two hours searching the net for info on this and came up empty. Thanks for the input.
Old May 10, 2005 | 10:20 AM
RaptorOwner's Avatar
Default FCR Carb
The tip of it may be bent.... I would go online to SUDCO and look up your carb on the diagram and see what it looks like.
Old May 10, 2005 | 11:06 AM
MURDR's Avatar
Default FCR Carb
Doesnt the stock fuel jet actually screw into another screw that you can take out with a socket wrench.
Old May 10, 2005 | 02:06 PM
maddog56's Avatar
Default FCR Carb
From the diagram that is shown in the manual, I should be able to back it right out. The screw takes a flathead screwdriver, a very small one and is recessed a little over an inch or so into the body of the carb.
The screws arent bent, the carb is new.
Old May 12, 2005 | 10:38 PM
maddog56's Avatar
Default FCR Carb
TTT, someone has to have installed one of these fuel screws.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
