any benifits??
Old May 12, 2005 | 09:18 PM
2strokegood89's Avatar
Default any benifits??
i just removed my oil injection system on my blaster.do you benifit from doin this (beside being able to control the mixture). for now im running 36:1. wat is a good ratio to use and can i get anymore power if i run it leaner or richer?
Old May 12, 2005 | 09:20 PM
WillSlamass's Avatar
i run regular pump gas in mine. it works the best
Old May 12, 2005 | 11:25 PM
im sure you put oil in there along with that pup gas to. wat is a ratio to make the most torque an horsepower if it is possible
Old May 13, 2005 | 12:23 AM
maddog56's Avatar
Depends on the oil and the bike. The manual suggests 24:1 on 2 strokes, most people run 32:1. I always ran Golden spectro at 50:1 as directed on the bottle.
Old May 13, 2005 | 01:23 AM
bl4cksh337's Avatar
you'll should run better than before because when you were rideing your blaster before you weren't always getting the perfect mixture and getting enough or to much and you should be running smoother now.
Old May 13, 2005 | 01:26 AM
Banshee392's Avatar
Now that youve got it injected off, run it with Amsoil Dominator at 50:1. [img]i/expressions/face-icon-small-wink.gif[/img]
Old May 13, 2005 | 01:09 PM
CTATV's Avatar
I run spectro synthetic blend at 36:1 in my quadzilla. You could get more power by running leaner for about 15 minutes until you melt your piston to your cylinder wall. other then that no you arent going to boost power by changing your mixture
Old May 13, 2005 | 01:25 PM
maddog56's Avatar
What? Lean or rich refers to the air/fuel mixture, not the oil/gas mixture. There are oils out there that run at 100:1, its all about the design of the oil and what you want out of it. If you dont have enough oil you can cook your 2 stroke, but as long as you dont thin the mix out any greater than is recommended on the bottle you should be fine. Many people run more oil because they are basically scared that thier bike is going to blow up all of the time. Its a type of insurance but if you run it with too much oil the bike will run like crap too.
MarkFiddling
Oct 26, 2005 02:20 AM
palebock
Apr 17, 2003 05:51 PM
Forcefed
Jan 9, 2003 11:32 AM
