Raptor Carb
Old May 14, 2005 | 12:36 AM
u's Avatar
u
Default Raptor Carb
How do you get the cable from the choke lever out of the carb???? I have the plastic nut out but cant get it out .
Old May 14, 2005 | 01:29 AM
u's Avatar
u
Default Raptor Carb
Help
Old May 14, 2005 | 01:55 AM
maddog56's Avatar
Default Raptor Carb
Go to ronnies.com or albaaction.com and look at a parts diagram for the raptor carbs, maybe that will help you. Or just download the manual online.
Old May 14, 2005 | 03:59 AM
u's Avatar
u
Default Raptor Carb
I got the choke cable out, I took off the top of the carb to try to get it out , but found out the hard way that it is a pain to put the rubber boots back under the cap, Now when i ride it. At higher rpm it sputters, I dont know if the rubber boot on top of the carb would make it a this way if they are not on correct.
Old May 14, 2005 | 04:02 AM
maddog56's Avatar
Default Raptor Carb
Its very easy to screw up the diaphrams in the top of the carb. They need to be set perfectly in their groove and not pinched off or torn at all. I would open it up and check it and try again.
Old May 14, 2005 | 04:04 AM
u's Avatar
u
Default Raptor Carb
So you think the sputter is the boots
Old May 14, 2005 | 04:09 AM
u's Avatar
u
Default Raptor Carb
Its around 2:00am and I put an ad in the paper to sell this thing, The ad starts tomorrow morring, Just my luck to have this happen, Ive had it since 2001 and never one problem until tonight.
Old May 14, 2005 | 04:36 AM
maddog56's Avatar
Default Raptor Carb
If you took the top of the carb apart, it very well could be the diaphram. The carb boots are between the head and the carbs, they are also well known for coming loose and causing backfiring.
BTW: its 3:30 here, and I'm going to bed. Good luck with it and I'll try and help tomorrow if its needed.
Firefighter400
Oct 8, 2022 06:38 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
black_thunder
Jul 9, 2015 05:58 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
