Banshee Owners
Old May 14, 2005 | 02:55 AM
rotty150's Avatar
Default Banshee Owners
I'm kicking around the idea to build a hillshooter out of my banshee and would like some different input on how to get the most power out of my Shee. Right now I have toomy t5 pipes, carbs bored to 27.5, stock reed cages ported,carbon tech carbon fiber reeds,bored .30 over, ported/polished. What else could I do to make it fly?
Old May 14, 2005 | 08:04 AM
Tpsycho's Avatar
My Bomb Busa is done now and WOW what a rush this thing is scary fast. I love it
If you want to run with the big boys you will need to Mill the head for better compression but you will probably have to run high octane fuel depending on how much you have milled off. Advance the timing with a adjustible timing plate this will let your motor rev to the moon also lighten your flywheel for quicker revs and get your tranny cut so you can shift gears at full throttle without using clutch or loosing RPM. And put her on alchohol.
If you just want your bike to run alot better mill 20Thousands off the head you should be able to run 91 fuel advance the timing and lighten the flywheel. This makes a huge difference in acceleration and make sure you have a good port job not a play port.
Good luck.
Old May 14, 2005 | 11:54 AM
SykoQuadRider's Avatar
If you wanna run witht he big boys your gonna have to fork out some serious money like the big boys. Period!!! Get a 10 mill cheetah or so. The cubs are looking good so far but to early to tell.
Old May 14, 2005 | 12:02 PM
rotty150's Avatar
I hear ya
95wolv
Sep 27, 2024 12:00 PM
Joe454
Nov 20, 2020 01:19 PM
Customer Service #1
May 15, 2020 08:46 AM
wendal
Oct 31, 2017 03:31 AM
Ahtatu
Sep 28, 2015 12:14 PM
