05 kodiak 450 needs valves adj.
Old May 14, 2005 | 10:52 AM
sedwick's Avatar
Default 05 kodiak 450 needs valves adj.
Can anyone tell me the procedure for this? Thanks.
Old May 14, 2005 | 11:49 AM
hondabuster's Avatar
Heres a generic article on valve adjustments, and should help describe what needs doing.
The toughest part, is removing enough stuff, to get to the valves, like fenders and gas tank and such.
the rope pull will need to come off, to access the sight plug, to line up the t mark, on the flywheel. The valves are adjusted cold, and the intakes are supposed to be .0024 -.0039", and the exhaust is .0063 - .0079".
article
Old May 14, 2005 | 12:05 PM
sedwick's Avatar
Hey thanks. I guess all i needed to know was were i could find the timing mark on the 450.
Old May 14, 2005 | 03:13 PM
kennybres's Avatar
is this a task the average guy can do? or should it be going to the dealer?
Old May 14, 2005 | 03:42 PM
I would think the average guy can check them, and if they are ok, then you saved money. If they are out of tolerance, then you can decide if you want to keep going, or button it up , and take it to the dealer.
If you can change oil, and spark plug and other basic repairs, then this shouldnt be very tough.
Scooter's Shop
23
Oct 22, 2015 07:04 PM
wrencher82
Sep 30, 2015 04:27 AM
wrencher82
Sep 28, 2015 10:02 PM
2many2ride
Sep 27, 2015 04:35 AM
maveikfe
1) Engine problems..
Sep 24, 2015 10:36 PM
