what size sand stars for stock yfz
Old May 15, 2005 | 11:54 PM
gonetothedunes's Avatar
Default what size sand stars for stock yfz
Sorry if this has been posted i tried searching a few times but could find the info i needed.I was just wondering what size sand stars to get for my yfz 450 it is stock,and im not to intrested in getting front tires just need to know what hight width and rim size to get.... thanks
Old May 16, 2005 | 03:15 AM
maddog56's Avatar
20" sand stars on 10" rims. 22" is only availible on a 12" rim and really isnt necessary on a v-paddle.
Old May 16, 2005 | 08:09 PM
thank you so i need 20/10/10
Old May 16, 2005 | 10:14 PM
maddog56's Avatar
The 10" rim will look and handle the best. The 8" rim will have slightly better floatation because of ballooning but wont expand much. The 9" will be in between.
If you are going with sandstars you probably arent that worried about drag performance, so I would say the 10" because it will handle better. That would be 20x11-10. The last number is the rim size.
Old May 16, 2005 | 10:20 PM
HughJazz's Avatar
You can get 20-10-9 and put them on your stock rims.
Old May 17, 2005 | 02:00 AM
will the 10 inch climb good or should i go woth the 9's if i plan on climbing i plan on doing some racing but not all the time i like to climb hills and sidehill, just play but i plan on buying new rims too so new rims are not a problem thanks for you help
rawbdiggity
Sep 7, 2015 12:05 PM
antiguogrumete
Sep 5, 2015 03:41 AM
lancemll88
Sep 5, 2015 03:16 AM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
