2004 blaster b1 pipe
At 3,000 feet elevation i was running a 310 with the needle on 3rd clip from bottom..Anyway's man i emailed this thread to my buddy and i know he will have you a awnser in the morning.. Anyway's sorry i couldn't help out but don't worry i know he will be able to..
By the sounds of things, your rich on the pilot jet which is why you have to have your air screw so far out. 2 turns isn't bad, and if you can get it to work good I would leave it. What size pilot do you have, still stock? Maybe drop the needle down one position (raise the clip) and see if it helps. When exactly does it start to bog, right off idle?
its a 2 stroke your not gonna have much bottom end, and if u lug it around all day u will fouel a plug, if u keep the rpm's up, then the toomey is a awsome pipe , i have a 04 blaster with toomey pipe kit, boyesen pro sereies reeds, reed spacer, vitos +4 degree key, 14,39 sprokets, k&n air filter,and razr tires and outrun 400ex's and z400s, u gotta dump the clutch for it to take off fast though
#16
i was just saying that if your used to riding a 4 stoke and then ride a blaster, its gonna fell like it has no tourqe, i have done a plug check a couple of times and my jetting is fine, and it revs quick ...and has ok bottom end snap, i think mine needs new piston and rings, compresion is low
mrtidy
Feb 3, 2016 05:00 PM
Sw00p
Sep 24, 2015 02:50 PM
