Blaster Carb Tuning
Old May 23, 2005 | 12:22 AM
yamahafan101's Avatar
Default Blaster Carb Tuning
As some of you might know, my 2004 Yamaha Blaster Piston pretty much melted, seized. Right now its getting fixed, and bored. My question is, how do I do a Carb tune for my blaster. I know where the screw is, but not sure how many turns out it needs to be for these NEW modifications
Toomy B-1 Pipe and Silencer
Toomey Jet Kit
No Airbox
Bore (Not sure what size bore yet)
Any help
I know you screw it in till it just barely stops, but i need to know how much for these mods, since the stock tune is 1 1/2 turns out i think
Old May 23, 2005 | 01:04 AM
RUFFCOUNTRY's Avatar
I have the same kit on my blaster, they tell you to turn the air pilot 3/4 from full in and needle position third groove from the top, but mine wont run properly unless its 2 turns from full in.
Old May 23, 2005 | 01:10 AM
you may have to do a plug chop to see where your at.
Old May 23, 2005 | 01:53 AM
Actually, better yet, <u>which direction makes it leaner, which makes it richer</u> . The I only have two screws, idle, and needle adjuster. I thought the jet just screws in, if not, tell me, most of the engine components are all off, so I can readjust the jet, but I thought the jet just screwed in, my dad installed it so, i dont know. I just need to know the optimal needle/screw adjustment for performance and cooling
Old May 23, 2005 | 02:43 AM
Bump
Old May 23, 2005 | 03:04 AM
adjusting the pilot screw in richens the mixture.
Old May 23, 2005 | 06:43 PM
Thanks, so maybe two turns out will do it. Ill try it once the engine is in.
Old May 23, 2005 | 08:51 PM
Shav0's Avatar
You want to have a smooth transition from wide open to idle when you let off. Open it up and then let off and listen to the engine, if it pops, pings, rattles, or makes any other sounds that dosn't sound normal your probably a tad lean on the idle circuit. In this case turn the screw in a bit to richen it up.
Old Jun 30, 2005 | 02:18 AM
Storj's Avatar
On my blaster when i have been reving it high and pull in the clutch and let off the gas it is still reved way up an only comes down when i let out the clutch a little just enough to make you move a little. Does that mean i was running to lean. I am curious to know because i just blew the piston and wasnt sure why.
Frisky2050
Apr 9, 2020 11:19 AM
GregM
Mar 6, 2018 06:53 AM
Aitch
Jul 21, 2015 09:40 PM
joeyupton
Jul 14, 2015 11:51 AM
maxjung
Jul 13, 2015 05:11 PM
