Warrior engine trouble
Was riding 3/4 wide open and it started bogging then died.Started it back up and sounded like a sloppy chain or something in front of motor.Is something wrong with timeing chain or what dont know wehre to start.Where would i have to start if it is the timing chain?If a ring let loose it woulda went boom right and died immeditly.i have no clue where to start.Thanks
Were, you able to get restarted? How new is the warrior? If you are experincing this ffrequently this could be a stator problem!
or you have garbage in your fuel and this is plugging up one of the jets not allowing fuel to pass through the carb. Hope this helps:
