O-ring chain link removal
Old Oct 9, 2000 | 12:00 AM
RigBoy's Avatar
On my '00 Banshee, I installed a 12t front sprocket to make up for the loss in bottom end power from my 22-12-10 Bearclaw tires. Now I am out of chain adjustment. Can I remove a link from my O-ring chain? I've removed links from other chains (not o-ring) but don't want to screw my chain up. Do I need a chain breaker? Anyone have any experience doing this?
Old Oct 9, 2000 | 12:20 AM
rottwolf's Avatar
Yeah, Rig, I've done it recently. Actually, twice. I was at my dad's, so I had his tools. I don't know about anyone else, but the chainbreaker was a waiste of money. My dad ground the plate, on a regular link, on the pin till it was smooth. Then we just tapped it out with a punch. I've had this problem, though. The chain wasn't a good size. I have a 12 tooth on mine too. It was either too loose or too tight, there wasn't any inbetween. I have also put a new x-ring chain on it, and had to remove a link.
Hope this helps,
Jason
Old Oct 9, 2000 | 05:40 PM
RigBoy's Avatar
Thanks rottwolf. Anyone else have any tips or suggestions?
Old Oct 9, 2000 | 08:03 PM
bermbanger's Avatar
Thats what I always do.
Old Oct 9, 2000 | 10:43 PM
RigBoy's Avatar
What happens to the oil inside when I remove a link. Obviously it will come out. Should I replace it with something or just leave it. Rottwolf said that chain breakers were a waste of money, any others have experience with them?
Old Oct 9, 2000 | 10:57 PM
TheQuadfather's Avatar
I've shortened many a chain. I used to use the grinding method, then I bought a good quality chain breaker, it's well worth the money. I got mine for $24.99 from Dennis Kirk. I wish I would have bought it long ago.
Old Oct 9, 2000 | 11:41 PM
rottwolf's Avatar
yeah, you need to re-oil your rings before you put them back on. Maybe my chain breaker was a cheap one? But it didn't push the pin out of a link for me. And it was a pain..I had to twist the handle to push the pin, it sucked.
Later,
Jason
National Motorsports
Aug 7, 2015 09:41 AM
ghost civic
Jul 27, 2015 03:15 AM
95wolv
Jul 17, 2015 08:13 PM
Unzzy66
Jul 11, 2015 10:01 PM
cSchwartz
Jul 9, 2015 02:43 PM
