Domes
Old Oct 9, 2000 | 02:31 PM
FMF's Avatar
FMF
What psi do I have to be to use pump gas.
I have 22cc Domes for my Banshee and would like to run 21cc or 20cc Domes
Old Oct 9, 2000 | 03:23 PM
BansheeBill's Avatar
From what I have been told, if you have 151 psi or better you had better run racing fuel.
Old Oct 9, 2000 | 03:32 PM
sAyIt_fmf's Avatar
like mentioned....as long as you don't over do it with your compression...you should be just fine.
I think you should be able to get away with close to 20cc domes without the use of race fuel.
From what I read on these forum pages...looks like everyone makes the change somewhere around 19cc for race fuel.
Old Oct 9, 2000 | 04:01 PM
YAMAHAPOLARIS's Avatar
I've got 20cc domes on my Banshee & run premium unleaded & have had no problem.
Old Oct 9, 2000 | 09:29 PM
blue_banshee's Avatar
well from what i have heard/read, 20cc is the border line, you may either run pump or race gas with these domes anything below is race gas material, nythig about is pump gas, if u would use race gas for a 21cc/22cc it is possible to hurt the performance
Old Oct 12, 2000 | 12:41 AM
peewee's Avatar
i use 19cc domes on pump gas. i live at 3200 feet and have approx 139lbs of comp cold. talk to an engine builder in your area and he will tell you what to use. i talked with kim muchmore and i havent had a single problem with my setup. i run 2 kns toomey pipes boysen reeds and it runs fantastic at the idaho dunes
Holyman
Mar 26, 2001 01:48 AM
Zorro
Feb 1, 2001 11:41 PM
Quadmaster24
Jan 20, 2000 01:08 AM
Aug 19, 1999 10:02 PM
