Warrior cam
Old Oct 11, 2000 | 12:52 AM
crazyfrmks's Avatar
I put a cam in my 99 warrior and it is a little bit loud. It is a high lift cam. I was told that a high lift cam will tick a little bit but I do not know I also have heavy springs in it also.
Old Oct 11, 2000 | 03:00 AM
scottd's Avatar
Did you adjust your valves to the CAM MANUFACTURER'S specs? Many times it is much different than stock. I have a hi-lift cam in my warrior, and it makes no more noise than stock.
Old Oct 11, 2000 | 08:24 PM
crazyfrmks's Avatar
Yes .004on intake and .005 on exhaust it is a white bros. cam It has lots of power but just ticks I don't understand it. I have had everyone I know look at it I just don't get it.
Old Oct 11, 2000 | 09:08 PM
YaMaRaPtoR's Avatar
I am wondering if you have ridden it like that?
If you keep hearing that its definately a valve out of adjustment, are you sure that you have the cam chain adjusted tight, and that the valve springs are installed right. You may need to readjust the valves after installing them. it is possible that under the higher stress of the cam that the adjustment may not hold, If so try and use loc-tite to hold the adjustment. If they loosen up too far you can kiss the entire top end bye bye.
Old Oct 11, 2000 | 10:13 PM
1BadWarrior's Avatar
I was thinking of putting a .390 lift cam, titanium valve springs and a 10.25 compression piston in my warrior. But everyone has told me that I would have to run race gas to get this to work. Is this true?
Old Oct 11, 2000 | 10:32 PM
88Warrior's Avatar
No, I have a .430 cam, titanium valve springs and a 10.25 wiseco piston in my Warrior and I don't have to run race gas.
Old Oct 12, 2000 | 12:56 AM
crazyfrmks's Avatar
I set the valves a little bit tighter that they called for. They called for .004intake and .005 on exhaust, I set them at .003 and .004 the cam said to set it at the 4and5 but it is alot better now and doesn't make as much noise and runs a like a bat out of h_ll Thanks for all the help guys.
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
