Warrior will not start, it just "CLICKS"
Old Aug 23, 2005 | 10:45 PM
warriorguy22's Avatar
Default Warrior will not start, it just "CLICKS"
the same thing happened to me last christmas, it was my starter... what i did was tap it with a wrench or something metal and it would usually turn over a couple times until i had enough to buy a new starter.
Old Aug 24, 2005 | 12:20 AM
paintballbanshee's Avatar
that happened to me, try replacing the 1 way gear and the battery
Old Aug 24, 2005 | 12:21 AM
is there a way to put a pull start on my warrior cauz i want 1 badly
Old Aug 24, 2005 | 12:39 AM
cruddymutt1's Avatar
Pull starts came on the early warrior. Not sure what years but my wifes 87 had one until I put the 440ex motor in it. You can get the pull starts for around 50 or so on ebay. I do not know if the newer Warriors have compression reliefs or not but you will need one to make pull starting way easier.
Old Aug 24, 2005 | 06:13 PM
  #15
RedNeckMXRider2's Avatar
prolly a bad cell in the battery
Old Aug 24, 2005 | 07:07 PM
  #16
Storj's Avatar
its most likely the battery my freinds raptor would just make a clicking noise and all he need to do was charge the battery and it works fine now
Old Sep 4, 2005 | 03:34 AM
  #17
Luke05's Avatar
My 96 warrior did that clicking. Just change the battery. Put the battery up in the winter if not riding. I have went through to many batterys leaving them out in the cold.
Old Sep 4, 2005 | 02:46 PM
  #18
recon99's Avatar
I think it's probably the battery too, but if you want to check the solenoid: short out the 2 large terminals on the top of it with a wrench or heavy gauge wire. this bypasses the solenoid. if the motor turns over you almost definitely have a bad solenoid
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
