Warrior Won't start
Old Jun 17, 2005 | 11:48 AM
MeYHymN's Avatar
Default Warrior Won't start
Check your ignition switch.
Old Jun 17, 2005 | 03:45 PM
Dement's Avatar
Well the winner was the fuse, Even though the fuse wasn't blown I changed it and everything worked.
Old Jun 17, 2005 | 05:31 PM
UltimateAussie's Avatar
sometimes the fuses are just broken enough to make them not work but not visible
Old Jun 17, 2005 | 05:57 PM
Vakero's Avatar
If you still have the fuse it may be helpful to check to see if is good. If you use an Ohm meter and verify it is good then you may have a loose connection at the fuse assembly.
njrider64
Jul 4, 2017 01:40 AM
Nelson
Jun 20, 2015 01:59 PM
mikey426
Jun 17, 2015 03:53 PM
1000gade
May 27, 2015 12:37 PM
dunc_n
Aug 26, 1999 09:32 PM
