blaster wont run
Old Jun 20, 2005 | 12:37 PM
DirtRyder420's Avatar
Default blaster wont run
my blaster is hard to start and wont stay running once it does fire, it seems like there is a sweet spot in the throttle about half way open where it will still run if i give it more or less it dies but its running weird almost like its trying to run good for 2 seconds and then cuts out for 1 I have done everything i can to the carb cleaned/played wit jets/tryed with and with out air filter/ and it still pretty much does the same thing so im almost sure it has something to do with spark i cleaned the plug and look for spark witch it does have but seems kinda weak does anybody know whats causing this or have any ideas ??
Old Jun 20, 2005 | 02:48 PM
86LT250RFatty's Avatar
check for a leek around the cylinder or going from the carb to the head. also, do a compression check
Old Jun 20, 2005 | 04:40 PM
240YBlaster69's Avatar
a compression test is good, i'd first replace the jets, i'd also have the wiring inspected. the stator might be going bad.
Old Jun 20, 2005 | 09:35 PM
the top end is just about brand new so if it is a comp. prob i must of blown a gasket or somthing but i do appreciate the advice b,cuz i wouldnt of thought of that so ill go over the cylinder tommorrw and give it a look ...thanks fellas
BTW how do i go about cheakin the stator ?
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1966F100
Aug 21, 2015 07:10 PM
scott1988
Aug 18, 2015 08:44 AM
315blaster
Aug 8, 2015 08:13 PM
