Raptor, jetting/lean mix problem.
Old Jun 27, 2005 | 12:41 AM
PolishCowboyPL's Avatar
Default Raptor, jetting/lean mix problem.
When I first took my raptor out this weekend, it was running really rough, even after warmed up, if you gave it about half throttle to accelerate it would bog before catching and going, I tried everything, idle screw, new plug, and so on, I did notcie the plug was a little whitish so I figured lean mix.
Also when you rev it up, it initailly lags before revinng
Since it only bogged in midrange, I took the needles out and moved the clips to the 4th slot from the 3rd.(I am completely stock, with stock jets) I had to leave my summer house but when I fired it up it didnt seem to be laggin on the rev up.
Any ideas? I need to know everything that can fix this by thursday cause thats when I'm going back.
Thanks,
MIke.
Old Jun 27, 2005 | 12:45 AM
I also did wash, and oil the filter, and fresh gas.
MIke.
Old Jun 27, 2005 | 12:48 AM
rapt660beast's Avatar
lol.. alright, oddley enough i just had this problem and just fixed it yesterday... what you need to do is get to the carbs, and when you get the carbs off the boots (make sure they were even on the boots first..) after you get them off the boots take them and turn them upside down, take out the brass screws, and there you will see one big jet in the middle (main jet) and then a thinner smaller jet right beside it.. (piolet jet i believe) but dont mess with those, there will be a screw in one of the corners that will be down inside the carb alil ways, that one is adjustable.. if its stock it should be at 2 turns.. either way it doesnt matter, your runnin to lean.. but turn that screw out another 3/4 turn, (make sure you do the same on the other carb) and it will run like a dream, trust me, i was puzzled for about 2 weeks on what to do. and called alba and they told me exaclty what to do. very easy, and doesnt take very long to do.. took me about 3 hrs to tare it apart and put it back togeather, and it will rev higher, and run like a whole new machine. lemme know how it works.
Old Jun 27, 2005 | 12:53 AM
Are you talking about the mixture screw on the outside of the carb?? the one about in the middle at the end where the intake box connects to? Cause I was thinking about that, but I figure I would try needles first before tearing the carbs off.
I never heard of a screw inside the carbs, do you know exactly wahts its called?
I'll take that into consideration too, thanks,
MIKe.
Old Jun 27, 2005 | 12:57 AM
alright, yeah, your right.. its on the outside of the carbs, but its easier to get to by takein it off, but yes, turn it 3/4 of a turn out. it will run great i promise, lol.
Old Jun 27, 2005 | 01:01 AM
ya ok thats what I was thinking, cause I don't know of any screw inside the carbs. But ya I guess I'm gonna have to change my needles back. Thanks, for the help.
MIke.
Old Jun 27, 2005 | 01:04 AM
not a problem. if ya need anymore help my aim is jami7713. take care
bmxatv10
Oct 14, 2022 06:23 PM
Beeline08
Nov 11, 2016 04:00 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
