cooling fan?
Old Jul 3, 2005 | 04:15 AM
ackademix's Avatar
Default cooling fan?
hey guys i used to be on here as sned but i forgot my password so im gonna use this again. my bruin 4x4 fan seems to go on ALOT i ride for 5 minutes and the fan goes on and if i go in the powerlines which it is 75+ degrees it goes on all the time. and if i put 4x4 on for 1 second fan goes on. is something wrong or is it working ok?
thanks
Old Jul 3, 2005 | 05:15 PM
ackademix's Avatar
any1? im planning on taking it out tomorow unless theres a reason i shouldnt
Old Jul 5, 2005 | 08:33 PM
ackademix's Avatar
went for the ride kept going on..anything i can check or is it normal?
Old Jul 6, 2005 | 04:13 PM
ddrumman2004's Avatar
My girlfriend's 2004 Bruin oil cooling fan will come on after a lot of slow riding on the land her mom owns which consists of hills mostly. There are a couple of shallow ponds she loves to ride through and the few times we have rode together, I have heard the fan come on a couple times. It shuts down after a fast ride across the hills although. We also ride it here at my house(2 acres) and I have yet to hear the fan come on here. Sounds like you may have a problem.
Bt the way, she puts it in 4 wheel drive when we ride through the woods on her place. I really can't tell that there is a difference in either mode as to which one makes the fan come on quicker. Mainly it just comes on when we ride slow.
Old Jul 6, 2005 | 05:43 PM
hondabuster's Avatar
The oil cooler is probably plugged up, by dirt and mud. sometimes you have to just about disassemble the front end, in order to flush the cooler well enough. Try getting right into it, with the garden hose, and make sure the water makes it thru. If the water doesnt flow thru, then the mud is probably dried and baked on, and you might need some more pressure to break thru. But keep at it, eventually the water will clean it out.
Old Jul 7, 2005 | 03:25 AM
ackademix's Avatar
its pretty new i got it like may 30th and i dont wanna screw with it myself will yamaha cover it or no..i can drive street and it wont go on but once im in sand it goes on after 5 minutes
IMLN
Sep 28, 2015 03:32 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
Polaris Side by Sides
Sep 15, 2015 03:33 AM
alzgarvin
Sep 11, 2015 08:53 AM
lancemll88
Sep 5, 2015 03:16 AM
