400ex clutch problems
Old Jul 21, 2005 | 05:37 PM
OneWheelWheelie's Avatar
Default 400ex clutch problems
what would cause the clutch handle to suddenly go stiff the problem isn't in the clutch cable. also clutch is slipping
Old Jul 21, 2005 | 08:50 PM
TehWarriorGuy's Avatar
wouldnt it make more sense to post in the Honda forum?!
Old Jul 21, 2005 | 09:35 PM
RacinJason's Avatar
If you are abusice or ride very hard it could be inn the clutch basket
clutches slip when worn out or over adjusted
is there free play in the lever/cable?
did you pull that cable off and make sure?
is the cable routed through the bike correctly?
BRAAAAP
skinnyr6
Aug 25, 2023 02:18 AM
Reactant
Mar 30, 2022 02:08 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
yambam13
Jul 4, 2015 01:49 PM
