top speed on raptor
Old Dec 13, 2007 | 04:35 PM
  #31
mr.spanky's Avatar
Default top speed on raptor
110 stock? did u unplug that sensor? i have an 02 660. stock no way that would go that fast. i have alot of stuff in it now, it may go 85
Old Dec 14, 2007 | 02:11 AM
  #32
Quad-Maniac's Avatar
The Rappy's (660 and 700) have a speed sensor on the output shaft that feeds the data to the CDI. WIth a stock Raptor, stock tires and stock gearing the CDI retards timing to prevent speeds above 75. The limiter can be over-ridden, but 'stock' it is what it is.
Old Dec 14, 2007 | 10:20 AM
  #33
RaptorRider09's Avatar
my 03 raptor 660r hit 76 ridin next to my uncles truck
Old Dec 14, 2007 | 02:47 PM
  #34
Well, I'd say that's just about within the measurement resolution of what I just described. Thanks.
No matter how many mods you do, if you want to go significantly faster you need to disable the limiter or go to larger rear tires or change the sprocket ratio.
Old Dec 16, 2007 | 05:20 PM
  #35
maddog56's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Raptor660Rshee350
I was replying to paintball banshee cause he was talking about strict emissions on carbs limiting top speed. Well the 700R is fuel injected so their is no carb emissions you know?</end quote></div>
C.A.R.B. is the "California Air Resources Board", not short for a carburetor. Emmissions come from the exhaust, not from a carburetor or fuel injector.
Old Jan 21, 2009 | 12:46 PM
  #36
micahd's Avatar
Default top speed on raptor"></title><script src=
i have a 03 raptor 660 with k&N intake and pro-circut T-4 pipe, no gear changes or other motor mods and i got a radared at 82 mph.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 12, 2015 09:39 AM
black_thunder
Sep 6, 2015 04:41 PM
