Pro design kill switch instalation
Old Jul 27, 2005 | 05:00 PM
ttam1147's Avatar
Default Pro design kill switch instalation
I have a 04 yfz450 and i dont know how to hook up my tether switch.Does anybody know how because i have a race this weekend and i need to have a working tether
Old Jul 27, 2005 | 05:10 PM
AnimalMother85's Avatar
find the your ignition wire, splice the killswitch into it, simple
Old Jul 27, 2005 | 05:23 PM
ttam1147's Avatar
is there more detailed instructions i dont know much about wireing
Old Jul 27, 2005 | 05:32 PM
ok, you have to wires comming off your killswitch, and you have one ignition wire(should be from your coil to where your key is, correct me if i'm wrong someone) You have to cut that wire from the coil to the key, and splice one end of the killswitch(the wire)to the one coil end of the wire you just cut, and the other and of the killswitch wire to the other part the you cut, where the key is
step 1: find the wire
coil--------------------------------key
step 2:cut the wire
coil---------- ----------------key
step 3: splice in the killswitch
coil---------killswitch--------key
when the teather is pulled, this creates open in the circuit, therefor there will be no current running through it, due to no ground, shutting off your atv. If someone knows a better way of doing this, speak up, help him out.
(this should do though)
Old Jul 27, 2005 | 05:41 PM
ttam1147's Avatar
thanks
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Ripinandtearin
Dec 11, 2017 08:06 PM
sweaver
11
Aug 18, 2015 03:47 PM
Hatrackr
Aug 11, 2015 09:03 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
