Engine Ice Coolant
Old Jul 28, 2005 | 12:33 PM
garrett5462's Avatar
Default Engine Ice Coolant
Does anybody here use it and does it really make your engine run cooler?
Old Jul 28, 2005 | 02:00 PM
DesertViper's Avatar
Yes, ... and yes.
I use it in my KTM 525 MXC, which is an even more radically tuned engine in stock form than a YFZ 450 is. If I were going slow, climbing rocky mountainsides in the pinion pines, I could get my KTM to start to loose coolant out the radiator cap vent. Or if I were going slow climbing big sand dunes in 102 degree heat the same thing would happen, because without enough airflow over the radiator it would overheat. I changed to the Engine Ice coolant, and made no other changes, and so far I haven't lost any more coolant. It seems to make a difference.
DV
Old Jul 28, 2005 | 05:24 PM
AlkyBurninX's Avatar
It works great. I have seen a 20* drop on a guage on a streetbike just by swapping coolants.
Old Jul 28, 2005 | 08:32 PM
Thanks, i guess i will be using it than since lots of the trails i ride on are slow.
Old Jul 29, 2005 | 01:09 AM
CoyoteRiverRaptor's Avatar
Any brands that seem to work better than others? TIA
Old Jul 29, 2005 | 03:30 AM
bansheeesmoker's Avatar
Redline works the best. I tried them all. The purple stuff works better than the regular rad fluid.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
SDR-II
Sep 29, 2015 01:06 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
Coryco
Jul 6, 2015 07:30 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
