anyone just tell me Banshee stock tires size and gearing
Can someone tell me what's the size of stock banshee tires (mostly height) and sprockets.
This week end, I saw a guy on his banshee, he could wheelie all day long...just smashing the throttle...I can't do that. I have 22" bearclaws, and I don't know if the previous owner adapted sprockets.
Front should be a 14 tooth.
Wheelies will be rough with the bearclaws.Not enough traction.I put a 12 tooth front on mine along with 22 inch sure tracks and it was rough to get the front end up in any gear.
I have since switched to 22" razr XC'x and the front got a whole lot lighter.Now with the sigle carb kit I just put on it's even better/worse depending on how you look at it.It may wheelie a bit to easy now.But I haven't had it out on the trails/hills to find out yet.
Greg
Greg
Stock rear tires are 20x10-9, so your 22" Bearclaws are 2" taller than stock. I have the same set up on my 2000 Banshee and love the Bearclaws. The stock front sproket is a 14 tooth and the rear is a 41 tooth. I just geared my front sproket down to a 12 tooth for more bottom end power
You can find any (stock) info on a yamaha here:http://www.yamahausa.com
2 2000 blasters too many mods to list.
