Grizzly Restoration Questions
Old Sep 23, 2005 | 01:10 PM
  #21
DonQ's Avatar
Default Grizzly Restoration Questions
I think I have a good lead. It's blowing air out of the carb, I'm assuming on the compression stroke. That would explain a lot. I'm going to check the valve timing.
Old Sep 24, 2005 | 11:46 AM
  #22
DonQ's Avatar
I checked the carb again and it's actually sucking in air as it should. But when I allign up the T on the flywheel, the cam timing mark is not spot on. It looks like the sprocket is advanced one tooth counterclockwise. Does anybody have instuctions on adjusting the cam timing on a YFM600?
Also, I think the backfire is coming from the exhaust stroke and it's because with a magneto, the sparkplug fires on both the exhaust and compression stroke.
John Reed
Sep 9, 2015 03:46 AM
bmark0610
Sep 7, 2015 09:42 PM
rawbdiggity
Sep 7, 2015 12:05 PM
Elkaholic
Sep 6, 2015 02:44 PM
OutRacing
Technical and How-To Articles
Sep 3, 2015 07:49 AM
