blaster performance
Old Aug 3, 2005 | 03:04 AM
Storj's Avatar
Default blaster performance
projectblaster.com offers a whole new top end piston and all for under $600 or you can spend a bit more like close to $1400 and get everything pipe, carb, new top end, piston, rings, gaskets, ect. http://www.vcatv.com/PBengine.htm
Old Aug 3, 2005 | 05:10 AM
Monolith's Avatar
If you are serious about wanting power do yourself a favor and dont go with an "out of the box" 240 cylinder kit (aka HWD, Vitos). What you need to do is find a reputable builder and have your engine built for what you ride and have the power hit where you want it. A builder like this will have your intrests in mind and will not only build a powerfull motor but a reliable one.
Old Aug 3, 2005 | 11:39 AM
FastYFMRida's Avatar
just buy the CT Racing 240 Sonic Kit, it comes with its own cylinder head already ported, i think it has a cr250 reed cage or something
41hp thne if you can buy a 4mm stroker...im just guessing but thats prob like 48hp right there? 45?
Old Aug 3, 2005 | 12:34 PM
ShadyRascal's Avatar
Whatever you do, you'll need more carb on that Blaster. On the cheap, you can do what I did, porting & head mod by Eric Gorr @ Forward Motion (about $165), FMF pipe, 30MM flatslide carb from Trenga, reeds, air filter, that's about it. Our Blaster with those mods makes big horsepower, stays close to our piped Z400 without a lot of money spent. Kills other piped Blasters, just murders them. The bigger carb really wakes it up though, the stock 26 really chokes it.
Old Aug 3, 2005 | 01:08 PM
  #15
paintballbanshee's Avatar
shady rascal is right about the carb, but id get a high performance white brothers carb at the end, i always jet the carb last..
Old Aug 3, 2005 | 02:20 PM
  #16
2strokesceamer's Avatar
Look at the project blaster phantom fire breathing 240 kit
Old Aug 3, 2005 | 11:42 PM
  #17
crazybmxrider's Avatar
well my blaster doesnt have a huge power band but compared to stock it aint to bad. i put on fatboy 2 silencer, clamp on k&n filter, reed spacer, jets.
Old Aug 4, 2005 | 05:58 PM
  #18
fastquad02blaster's Avatar
How much good would a reed spacer and reeds do. Would it be noticable?
Old Aug 4, 2005 | 06:05 PM
  #19
it wont be a noticible dfference
Old Aug 4, 2005 | 06:14 PM
  #20
i heard the v force reeds make a huge difference. i put a spacer on mine and it mid range power. or if u want somthing cheap u could get a vito advace timing key. there like $20 and there suppost to make a pretty big difference.
