bLASTER bRAKEs
Old Aug 9, 2005 | 12:04 PM
Boombotz's Avatar
Default bLASTER bRAKEs
Guys my rear brakes sqeek when i roll my quad do i need a whole new back brake or do i just need new pads and my rear break is shot i have no stoppage with my rear break at all what should i do?
Old Aug 9, 2005 | 12:09 PM
garrett5462's Avatar
you should only need new pads.
Old Aug 9, 2005 | 01:24 PM
TheTurtle's Avatar
the best thing for you to do if you have an extra $200 is buy an aftermarket hydraulic brake kit. the rear brake on the blasters suck!! i forget who makes them but i know the cheapest place to find one is ebay. and DO NOT buy a used one!!!
Old Aug 9, 2005 | 02:51 PM
EclipseYFS's Avatar
Either buy a hydraulic brake kit like the guy above me suggested... or do what did, ditch the entire rear brake setup. Save about 2-3 lbs. [img]i/expressions/face-icon-small-wink.gif[/img]
Otherwise try new pads... [img]i/expressions/face-icon-small-sad.gif[/img]
Old Aug 9, 2005 | 10:10 PM
fastquad02blaster's Avatar
I fabricated a 300 ex setup onto mine. I made all the brackets and welded them and bolted them on my quad, filled it with fluid, bled all the air out and now it will lock up the wheels, wet or dry without a problem. I bought it all for less than $125.
Old Aug 17, 2005 | 10:40 PM
Storj's Avatar
i dont know why everyone thinks the rear brakes on the blasters suck because i can easily lock up my rear wheels maybe you all need to grow some mucles and learn to push down with your foot just buy new pades and youll be set
Old Aug 18, 2005 | 01:45 AM
blasterchild's Avatar
easiest and cheapest way to go is go for a used banshee caliper and master cyl. off of ebay and make your own mounts.
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Ahtatu
Sep 28, 2015 12:14 PM
nastyblaster100
Sep 13, 2015 01:19 PM
