Any BAD 04 raptor one-ways?
Old Sep 16, 2005 | 12:48 PM
grapestomper's Avatar
Default Any BAD 04 raptor one-ways?
I found by searching that "Knowsalot" posted a thread on changes for the 04 raptor, but the last thing mentioned about " is it a fix?" was that time will tell.
So , has anyone had to replace their one way starter clutches on 04 or newer bikes? I am looking for a second raptor 660 and want to know if I can avoid the $255 bill for a new one-way starter clutch, ala LA Design's mod.
Thanks
Allen
Old Sep 16, 2005 | 03:10 PM
maddog56's Avatar
Yes, the 04 and 05 models have problems with them too. Ripper Racing has 04 L&A one-way kits in stock and has sold quite a few. Its not a fix, but it was marginally better.
Old Sep 16, 2005 | 05:27 PM
Thanks maddog56
To further the discussion... is the LA one way I just installed in my son's 03 a better fix than the 04 and up unit, or are they the same? I assumed the one way on the 03 was a one time change, although I did see some one way's had cracking issues in another thread.
So since the 04's have one-way problems, is an 03 as good as an 04? I was strictly thinking the 04 was a better choice than the 03, but it sounds like they have the same issues .
Thanks for any other suggestions,
Allen
Old Sep 16, 2005 | 06:41 PM
warrior007's Avatar
the 04 is alot better, but time will tell. 04's are almost 2 or 3 years old now, about the time most have gone or are going out already when ridden regularly.
Old Sep 16, 2005 | 07:18 PM
Thanks
The scary part to me is, on our 03 it had ( according to tire wear and orig owner) 3 fueltanks full of use, and it growled and kicked back when shut off. Due to research here I knew not to keep running it, but I am sure if I didn't find this website we would have kept running it and making gobs of metal chips in the crankcase... ie a USED bike has it's faults.
I spent more than an hour with oily towels removing all of the metal flakes I could find, and installed a magnetic drainplug to catch the flakes I know got away....The needles on the old oneway had substantial flatspots, indicating lots of metal flakes were made.
Thanks
Allen
Old Sep 16, 2005 | 10:03 PM
RacinJason's Avatar
change your oil filter
pull the line from the bottom of your oil sump and clean that screen as well
Old Sep 16, 2005 | 11:50 PM
CTracingraptor's Avatar
i change my oil often on my 02, and its had NEVER had a problem with the starter or the one-way.....knock on wood.
Old Sep 17, 2005 | 12:16 AM
HappaRap's Avatar
Lazy Boy Rider!
My 02 one-way lasted 1 1/2 yrs, don't start it in gear with the clutch pulled in, always start in netural with the clutch pulled in, I've heard that helps, but then I have an L&A in presently. I wonder if there's gonna be any issues with the 700R one-way?
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
