Raptor radiator fan
Old Sep 24, 2005 | 09:02 PM
RockyLou's Avatar
Default Raptor radiator fan
My quad has been overheating alot and I just found out that my radiator fan hasn't been coming on. I'm trying to check the connections but they look alright to me. Has anyone ever experienced problems with this before?
Old Sep 24, 2005 | 09:34 PM
fasterthanyou22's Avatar
Yea bud, i had a problem like that with my z400.It is a fuse near the sensor.There should be a spare one in a hatch right next to the actual place where the fuse connects.I can almost guarrentee that is what the preoblem is.
Old Sep 25, 2005 | 11:49 AM
HappaRap's Avatar
Lazy Boy Rider!
I've never had a problem with the fan, can't help you out there.
Old Sep 26, 2005 | 12:06 AM
MasterRaptor's Avatar
It's probably the sensor in the radiator. They only last a couple years. I had to replace mine. Its located in the lower tank to the left of the hose. Un plug the cable, stick a paper clip or something in the plug to short the two wires together. Make sure the key is on. If your fan comes on when you short these two, then you need to replace the sensor. If not, then there is a bad wire or blown fuse. You will have to trace the wires. Sometimes, a wire will break in the connector bundles where the front and rear plastic meet.
Also, try putting power directly to the fan plug top make sure the fan works.
Most likely, its the sensor...an easy fix.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
