Need help with warrior
Old Oct 3, 2005 | 04:02 PM
georg's Avatar
Default Need help with warrior
jUST GOT A 2002 WARRIOR. wHEN THE CLUTCH IS FULLY DEPRESSED, IT STILL MOVES A LITTLE. Also, when i put it in reverse, it wont go back into forward unless i shut off the machine. Also, it never wants to go into neutral until it shuts off. Is this just a clutch adjustment needed? Any help would be appreciated.
Old Oct 3, 2005 | 08:37 PM
AZDUNERAT's Avatar
You need to adjust the clutch, if your luck it will be easy and just the cable, however you may need to pull the cover and adjust the lever in the case. This is more than likely your problem with reverse as well. You dont want to mess with this or you will start grinding gears down
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
Barnsnelbon
Sep 27, 2015 03:07 AM
Bernhard
Sep 25, 2015 12:45 PM
01ssls1
Sep 22, 2015 06:50 AM
