Snow plow for my Grizz?
i got mine at
www.gowarn.com
i use the manual lift for the plow,i think its faster than using the winch,and it saves the cable,,,others seem to prefer the winch,that may be a personal preferance thing for you to figure out
www.gowarn.com
I had a Warn when I had my Grizz. I would say the winch setup all the way. It works very smooth. It runs around a pully on the blade making the winch hardly break a sweat. And I know at least mine you could crank up very high, makes it easy if you have to go through any trails.
it may be dependant on the size of the blade you choose,,,i chose the 48" because it was light,and i would still be able to maneuver
with ease,and easier on the bike all round,and i wasnt putting wear,and tear on my winch saving it for what it was intended for,,i guess if your going to get a larger plow,the winch would be better,but i wasnt trying to compete with the county roads commission,i just needed to be able to plow my somewhat long drive(but not real long),,,also if you go with the larger plow,your going to need to be adjusting the shocks back,and forth to keep the front from dipping from all of the weight,again i just wanted to be able to plow my drive,and wanted to keep it as simple,painless,and fast as i could
the warn too is easy to take on,and off
TheATVSuperStore.com
TheATVSuperStore
09-09-2015 07:43 PM
