2 stroke oil
Old Oct 17, 2005 | 10:20 PM
artic56's Avatar
Default 2 stroke oil
I was just wondering if it is ok to use transmission fluid in the bottom end of a 2 stroke.
Old Oct 17, 2005 | 10:49 PM
MDS2106's Avatar
I have heard of quite a few that run typeF trans. fluid in their banshees.I run tractor hyd. oil in my banshee trans. and have not had one bit of trouble.I tried motor oil but it seems to shift alot better with the hyd. oil.Tractors run a wet clutch system also.The hyd.oil is cheap enough that I change it about third ride.
Old Nov 7, 2005 | 08:05 PM
artic56's Avatar
ANY ONE ELSE
Old Nov 7, 2005 | 09:07 PM
enFORCER's Avatar
I run Klotz flexdrive 30 in the transmission on my Banshee...
Old Nov 7, 2005 | 09:17 PM
mywifesquad's Avatar
KTM Patrol
Former Chinese POW!
I use Bel Ray Gear Saver 80wt in the tranny of all my 2 strokes.
Old Nov 7, 2005 | 10:51 PM
1BAD250R's Avatar
I run Motul tranny oil in my R. Fluids are one area you don't want to go cheap on. Spend the money for the best and your bike will last longer.
Old Nov 30, 2005 | 07:50 PM
CertifiedDunatic's Avatar
i either run castrol type f or klotz flex drive 30
exmotocrosser
Sep 13, 2019 06:12 AM
exmotocrosser
Sep 26, 2015 08:18 AM
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
