Raptor 700 kill switch
Old Oct 20, 2005 | 08:59 PM
GreenBeast's Avatar
Default Raptor 700 kill switch
I'm trying to put a pro design tether kill switch on the raptor 700 and cant figure out were on the bike to hook up the positive wire from the switch. Anyone know? I would greatly appreciate any help. -- D
Old Oct 21, 2005 | 11:03 PM
HappaRap's Avatar
Lazy Boy Rider!
No clue, just a bump for you.
Old Oct 22, 2005 | 01:16 PM
GreenBeast's Avatar
Thanks, I'm beginning to get really frustrated with this thing. The dealership doesn't even have a clue as to were to put it. They told me to wire it to the on/off swith on the handlebars, but all that's doing is blowing the ignition fuse. Oh well I'll keep trying till I get it or fry the ECU.
Old Oct 22, 2005 | 06:34 PM
GreenBeast's Avatar
Feels like I'm asking questions in vain on here nowadays. Seems like if you don't ask which bike is faster, or trash talk you can't get a reply. Well anyways, I've got it figured out after a day of cursing, and going through nearly 10 fuses. So here it is. Grind off some of the paint anywhere on the steel part of the frame and bolt on your ground wire (short wire for Pro Design Kill Switch). Attach the pos (longer wire) to the "negative" wire on the coil pac, (all the instructions I found said to use the pos coil wire, but all this will do is blow fuses). It is the bottom negative wire (orange) that you want. Solder it in and tape it up good and your done. Hope this helps someone not have to go through the mess I have dealt with today.
Old Oct 23, 2005 | 12:06 PM
HappaRap's Avatar
Lazy Boy Rider!
Thank you very much for posting your results, I'm in total agreement with you on the posting issue.
Old Oct 24, 2005 | 03:12 AM
quadbike's Avatar
Thanks for the info GreenBeast [img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 24, 2005 | 09:53 AM
Raptorflash1's Avatar
Thanks for the info. I wonder why the neg side instead of the positive side of the coil?
Old Oct 24, 2005 | 12:57 PM
Air's Avatar
Air
The negative side of the coil is probably the switching side and grounding it out will not let any spark happen.
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Ripinandtearin
Dec 11, 2017 08:06 PM
sweaver
11
Aug 18, 2015 03:47 PM
Hatrackr
Aug 11, 2015 09:03 PM
Ripinandtearin
Jul 19, 2015 08:38 PM
