YFZ450 backfiring..Plz help
Old Oct 25, 2005 | 12:21 PM
nmd3228's Avatar
Default YFZ450 backfiring..Plz help
I have a 2004 YFZ450 that has been made into a CT 470 with a 13:1 piston. Put it in, re-jetted to a 45 Pilot 165 main. There is considerable valve noise, Bike is backfiring and won't idle. Will a valve adjustment cure this or is there another problem?
Old Oct 25, 2005 | 12:50 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Valves could be out of whack, or it also sounds like it could be out of time.
Old Oct 25, 2005 | 04:24 PM
nmd3228's Avatar
I brought it to a shop. They said the valves have been adjusted and the timing is correct but it is still backfiring. They think it is running way to lean and are going to put a 50 pilot and 185 main...This sounds like alot...any help appreciated.
Old Oct 25, 2005 | 04:54 PM
motox26's Avatar
Shed Knocker Rider
Harley Punk!
Running really lean would make it spit and sputter like you say, but I don't know why it would be making a lot of valve noise.
Old Oct 25, 2005 | 06:30 PM
BigWaynester's Avatar
does it just backfire when you let off throttle? maybe one of the jets in the carb is clogged, what is the air/fuel screw set at? may be your ign box?
Old Oct 25, 2005 | 06:45 PM
nmd3228's Avatar
It has brand new jets in it..The air/fuel screw is 3 1/2 turns out...How can they check the CDI box?
Old Oct 25, 2005 | 07:04 PM
the only way I know is plug a different one in. I have one you can borrow, if you can't figure out why it is backfiring and not running right. Also make sure the wires are plugged in that come out of the carb. your problem could be the TORs or TPS is not connected or out of adjustment.
Old Oct 25, 2005 | 07:15 PM
You can by pass the TPS and see if that is your problem, or in the service manual it tells hou to adjust it.
Old Oct 25, 2005 | 07:22 PM
nmd3228's Avatar
will try that next thanks for the advice...I was also told that maybe a rubber in the carb went bad and that is a common problem on the YFZ..ever hear of that?
Old Oct 25, 2005 | 08:46 PM
HughJazz's Avatar
post at http://www.yfz tech.com
Top
© 2026 MH Sub I, LLC dba Internet Brands
Follow Us
