Need some help with a nut on the cylinders
Old Nov 4, 2005 | 10:56 PM
03TRX300ex's Avatar
Default Need some help with a nut on the cylinders
Need some help with a nut on the banshee's cylinders. It was strip when I was taking the cylinders off for porting. How can i get it off? I live in near miami, Florida
Thank you guys so much.
http://www.bansheehq.com/forums/inde...howtopic=52349
http://www.atvflorida.com/forum/inde...ic,8252.0.html
Old Nov 4, 2005 | 11:22 PM
MDS2106's Avatar
Take a standard size socket just smaller than the nut,tap it down over the nut ,its going to be a snug fit but it might be enough to break it loose.Craftsman also sells a nut removal kit that works really well but I don't know if the sockets will fit down into the head?I have the kit at home I will see if it will fit down in side the head in the morning when I get off work.
Later
Mark
Old Nov 6, 2005 | 12:28 AM
03TRX300ex's Avatar
thank you
Dewhound
Apr 20, 2017 02:25 PM
Jaymc
Sep 11, 2015 07:45 AM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
