raptor 660 suspention ?? plz read
ok i have a chance to get some really nice custom axis shocks but the thing is there 16 inches long hole to hole. The bottom mount opening is 1 1/4 inch wide will this work on the raptor rear if so is it going to raise it at all? and axis fronts that are 16 1/4 inches long hole to hole. will this raise it ? i think its 15 and 1/2 is the stock fronts on the rappy i could use any info thanks for the help
Stock is 15 1/2 give or take a 1/4. LT setups are typically a little longer at 18 or 19 inches so you're kind of in between. While they arent going to be the best for geometry, they are probably excellent shocks. I think if you get them revalved for your bike (and get rid of some preload) then they'll work fine.
