how many mm bore is a 310r
Ok here the problem my friends has a 250r with a hotrod stroker crank that is +2mm and its a 310 well its wore out and he needs new rings and we dont know how to tell how many MM the piston is to get rings for it can anyone help us
Can't you just measure the piston with a caliper???
all I know.......from my math........is that volume of a cylinder is (pi)(r^2)(h)
Where r would be your radius(bore), and h is your height(stoke)
I believe its a 74.5mm bore that would make a stock cylinder stock bore machine a 310. Not sure what kind of setup your buddy has, but if he's replacing rings and piston he should hone out then measure the cylinder to get the right size. Most of the pistons in that size are availible in half mm increments.
