Yamaha Blaster
Old Nov 10, 2005 | 09:57 PM
00twin350's Avatar
Default Yamaha Blaster
I have a 1994 Blaster it is completly stock. i blew a piston on one weekend i got a weisco piston and put that in did a couple little ride arounds to break it in then couple weeks later went to the monuds and blew another piston...i had switched to synthetic oil could that be the problem?
Old Nov 16, 2005 | 09:01 AM
blasterbrother210's Avatar
what are tard stick with yamaha lube or weedeatr oil saves a bunch of green$$$$$$[img]i/expressions/face-icon-small-confused.gif[/img][img]i/expressions/face-icon-small-mad.gif[/img]
Old Nov 16, 2005 | 09:03 AM
Originally posted by: 00twin350
I have a 1992 Blaster it is completly stock. i blew a piston on one weekend i got a weisco piston and put that in did a couple little ride arounds to break it in then couple weeks later went to the monuds and blew another piston...i had switched to synthetic oil could that be the problem?
how much do u want for the 94 blaster
Old Nov 16, 2005 | 10:14 PM
00twin350's Avatar
the piston is still blown and people told me 1000 not fixed and 1700 fixed
Old Nov 17, 2005 | 06:00 AM
lethaface's Avatar
Dude 1000 fixed is way high!!! ..Even if it did bottom end damage it still shouldnt be that much..Hell, you can get a whole motor off ebay for 6-700 bucks..DId you replace the wrist pin bearing when you rebuilt it?? Also when your putting the cylinder back on its best to put some premix on the cylinder walls..Even with a crappy oil i don't see it lasting 2 weeks then blowing again..Sounds like your jetted lean or you have a air leak..Either of those 2 things will destroy the little 2stroke motor..
Do you still have your oil injection on your bike? People say that the plastic gear that works everything is bad for stripping and cutting the oil to the gas..That would also be something you might wanna check on a 10 year old motor.. You should just take the motor apart and check and see whats up with it..Its very easy to do..If you still have any bores you can go just take it to a machine shop with the piston your going to use and they can do it for you.. Thats if you wasn't on your last bore, blasters can go to 80. over before they have to be resleeved [img]i/expressions/face-icon-small-happy.gif[/img]..
If you can't find anybody locally to do it under 500 try these guys www.cpcustoms.com ..They can do insane stuff with the blaster motor [img]i/expressions/face-icon-small-happy.gif[/img]..They have vids a 6mm blaster (215cc) waxing 450's and modded banshee's
Old Nov 18, 2005 | 05:21 PM
00twin350's Avatar
900 not fixed 1100 fixed
Sep 17, 2015 03:06 AM
nastyblaster100
Sep 13, 2015 01:19 PM
Yamaha Side by Sides
Sep 8, 2015 01:43 PM
