Blaster Clutch problem Please Help
Old Nov 16, 2005 | 11:23 PM
hondarulesinnc's Avatar
Default Blaster Clutch problem Please Help
About 2 months ago we replaced the clutch cable on our blaster. An old clutch cable, sure its gonna break, so we put it on and it worked fine, but then a few weeks later just all of the sudden the clutch got about 3x harder to pull, and there was no indication of what went wrong or was going wrong, so tonight after I put a new 13 tooth sprocket on I went out for a ride to test it out, I was coming home, pulled the clutch to downshift, and the cable broke. Luckly I was close to home so I did not have to go far, I took the cable out and it slide smoothely. What could be making this happen, and most importantly what can I do to fix this so I don't have to replace the clutch cable every 2 months?
Thanks for the help.
Old Nov 17, 2005 | 12:24 AM
bonebreakers's Avatar
keep it lubed, seen when u wash them water stays at the bottom of cable were the boot is.also check after u put a new one on when pulled all the way does it rub the lever.
Old Nov 17, 2005 | 11:02 AM
After the cable broke I pulled the cable in and out, and it had very little resistance, but not enough to account for all of the extra force. I tryed to turn the lever assembly on the case and it was extremly hard to turn.
Old Nov 17, 2005 | 01:33 PM
Blastermaster2's Avatar
Make sure you don't have to much oil in the trans, more oil will cause a harder clutch pull, also, if you ever are in the vicinity of the clutch, check to see that your clutch basket, or the friction plates aren't broke.
Old Nov 17, 2005 | 11:39 PM
Could running the an oil that is too high of a weight also cause this problem? I just found out today that I have been adding the wrong type of oil for the past 6 months so it is about half full of the wrong type of oil. It leaks a little oil so it is slowly going up and down from time to time.
skinnyr6
Aug 25, 2023 02:18 AM
Frisky2050
Apr 9, 2020 11:19 AM
honda71
Jul 12, 2015 05:56 AM
200es
Jul 10, 2015 09:09 AM
coolguy420
Jul 10, 2015 01:17 AM
