1998 Yamaha Warrior engine knock
Old Nov 24, 2005 | 12:28 AM
cheitman's Avatar
Default 1998 Yamaha Warrior engine knock
My Warrior engine has a knock that seems to originate from the bottom end. Compression is at 140PSI and it seems to start and run as normal. Are there any common issues with these that i should look for?
Old Nov 24, 2005 | 01:18 AM
YBlasterboy's Avatar
Check the oil.
Old Nov 24, 2005 | 02:34 AM
cheitman's Avatar
That's the first thing i checked.
Old Nov 24, 2005 | 11:22 AM
MasterRaptor's Avatar
Put a socket on the crank and turn it by hand against the compression back and forth. If you hear a knock or tap, then the problem is piston slap.
Also, if the knock is louder when it is cold, then it is most likely piston slap. It may be time for a fresh top end.
I wouldn't think that the low end would make noise. Usually, that's solid unless yiou ran it out of oil.
Old Nov 26, 2005 | 12:50 AM
cheitman's Avatar
I puloled the motor out and began disassembly. I have not pulled the cases apart yet, however, everything turns nice and smoothly with no noticable crank or rod play. The cylinder is std. bore and measures at 3.265. Piston is good but ring gaps are in excess of .020. the only thing i found that could cause a knock is that the clutch basket had a lot of play and can be rocked back and fourth. I don't know if this is normal of not. Any suggestions? Should i go ahead and split the case. Valves were adjusted within reason and timing chain is ok. HELP!!!!!
Old Nov 27, 2005 | 12:31 PM
cheitman's Avatar
I figured it out. Looks like the piston pin is loose on the rod.
KimSJoh
14
Jul 18, 2015 07:20 PM
RedRancher
Jul 10, 2015 06:36 PM
MNatv89
Jul 7, 2015 11:36 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
Shifts
Jul 3, 2015 07:59 AM
