Need Blaster Info
Old Nov 27, 2005 | 01:23 AM
BizNutz's Avatar
Default Need Blaster Info
Ive been looking for a new quad to buy and i was thinking of getting a new Blaster. Is it true that blasters break down after a few months?
Old Nov 27, 2005 | 03:30 AM
CertifiedDunatic's Avatar
Old Nov 27, 2005 | 03:36 AM
No this is not true.Tee blaster is extremely relable, if you do the required maintenence. Depending on where you ride your maintenence will be different. If you ride in the sand you will need to clean your air filters every 4-6 rides. You will need to change the oil every 6-10 rides . The final most important thing is that you need to remember to add a good synthetic pre mix.I would recommend either Klotz or maxima. Depending on your size and weight the blaster will probably be a good starting point.
Old Nov 28, 2005 | 11:36 PM
Storj's Avatar
Who ever told you that must not know what they are talking about. As long as you keep up on maintenence as Dunatic said you should be fine.
Old Nov 29, 2005 | 05:59 PM
yfs200rider02's Avatar
keep up on the maintiance and do not keep revving high in first gear because ull crack ur piston...i did that and i payed 1000$ to get it fixxed
Old Nov 29, 2005 | 06:06 PM
Z40005BR's Avatar
Yeah i had a blaster before I upgraded to my Z and it was pretty reliable.
Old Nov 29, 2005 | 07:35 PM
Storj's Avatar
$1000. to get a motor redone. You got ripped off really bad. It cost me $180 in parts and getting it bored and i did all the labor. But $1000 is just rediculous you can get a full out raciing motor for that. Oh and dont hold the throttle pinned in any gear to long or you can blow your motor.
buddieboy
Dec 9, 2016 05:50 PM
Ahtatu
Sep 28, 2015 12:14 PM
exmotocrosser
Sep 26, 2015 08:18 AM
woodthings
Sep 25, 2015 05:58 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
